Mark.W
Hi Chaps
Just a quick one! I have not worked with soft starts very much! So forgive my lack of knowledge pls!
How do we control a soft starter?, does it have to be via a 24v or 120v control circuit? Or can we use the mains supply?
I am using a Schneider ATS01N222NQ 11 kW soft start to run a 7.5 kW fan unit via a 7.5 kW contactor. The contactor is operated via a start/stop button which supplies the soft start with 400v, the output voltage through the soft start is 395v which is kind of what I expected (as the voltage range is 30% - 80% full line voltage), however the fan will not move!!!! I was under the impression soft starters just needed a supply, and the soft start would do the rest!
Any help would be much appreciated pls
Mark
Mark
