SolaeEdge consumption metering | on ElectriciansForums
Discuss SolaeEdge consumption metering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Just received this in an email from SE. Can anyone supply the referenced meter and sensor?
Expert corner - Consumption metering
Did you know that the SolarEdge monitoring portal can monitor the site's consumption in addition to the PV production? To do so you should connect a meter available from SolarEdge to the inverter’s RS485 port or use a meter with an S0 interface and an S0 meter adapter cable available from SolarEdge. For sites with multiple inverters, connect the RS485 meter to a SolarEdge Control and Communication Gateway (CCG). Read here how to connect the meter to the inverter/CCG and how to configure the inverter/CCG.
http://www.solaredge.com/files/pdfs...Edge Monitoring Portal updates&utm_term=meter
Reply to SolaeEdge consumption metering in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
