Solar and Mains metering | on ElectriciansForums
Discuss Solar and Mains metering in the UK Electrical Forum area at ElectriciansForums.net
alfier
swindon
I have solar which sends excess watts to the mains. I would like a clip on meter that would show what power I am exporting or importing,
Can you not just view/use your smart meter?
You can get clip on ammeter, but this won't be accurate because you need both volts and amps to get the watts (if you assume 230V , there is likely to be an error as the volts could be 230V, or 240V, or 250V etc), you also can't get the direction without including the voltage, so a clip on ammeter might say 10.4A , but you can't tell if it's export or import.
Reply to Solar and Mains metering in the UK Electrical Forum area at ElectriciansForums.net
Thanks guys, that was my alternative thought, as I am running a cat 5 cable for Internet so it has crossed my mind to run another one for the CT...
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
