Discuss Solar Limpets in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm not sure I really want to get involved in this, but what "movement / bending action / stress points around the hole" are you referring to with a hanger bolt, and why do you see this as problematic?*It's quite an intersting discussion on slate - it's currently going through MCS012 for slate - the point is how it fits, where the loads are transferred to, how any holes are sealed. It is a lot better than a hanger bolt which has a movement / bending action / stress points around the hole. I am reserving judgement on slate at the moment. However as an engineer having been involde in constructionm for >30 years, i can see all the arguments. hence judgement reserved..
I'd think we've installed in the region of 30 systems on slate, yorkshire stone, cotswold slate, and fake slate roofs, as well as metal, and fibre cement. That's probably getting on for 1000 bolts installed, with zero reports of any problems related to the bolts, and no evidence of any problems at the few we have had call backs for for other issues.I am starting to agree with you Gavin, although we have not used it hanger bolts do sound like a good solution for slate. If a hanger bolt works for sheet fibre cement sheets why would it be a problem for slate? Very interested in the limpets though.
Reply to Solar Limpets in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
