Hi all
I'm looking for some help on a query I have.
I'm currently involved with a new build with the plan to fit Solar in the very near future, which I have never installed before or had any experience.
The plan is to fit a 3.4kw system and i wanted to put in the cable ready from where the inverter will be positioned down to the consumer unit, it will have a run of approximately 7 mtrs.
The query I have is, can I use standard 4mm2 grey T&E cable from the inverter down to the meter, then to the consumer unit, or do I need to use special Solar Cable?
Any help or advice would be much appreciated
Kind regards
Steve
Kind regards
Steve
