solar panel diode | on ElectriciansForums
Discuss solar panel diode in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
tom79bmth
Hi All
Just a quick question, I brought a cheap solar panel off eBay to keep my battery charged on my camper van.
I was just having a look at it to see if it has a blocking diode! there is a diode but I'm not sure what it is for as there are no markings on it. It's joined between live and neutral on the panel is that a blocking diode if not what's it there for ?
I'm assuming you have a dedicated solar panel running at around 12.5-14.8v designed for charging leisure (car batteries, I'm assuming 12V d.c.). If so this panel is designed to be used by itself therefore no bypass diode required.
That diode will be purely for reverse polarity protection in case you connect the battery up wrong.
Otherwise if it is a PV panel see post #2
from what I remember blocking diodes are on the positive pole only, no negative connection, hence my comment.
Reply to solar panel diode in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I wish I needed a solution to me keep needing get batteries out my 6m boat!
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
