M
Motters
Hi
I had a solar panel system fitted 22 Feb 2012. The system includes a 15 panel sharp 245 array split into 2 strings of 9 and 6 running into a Sunny Boy 4000TL.
They system seems to produce consistently until about midday then cut out for periods if there is a decent amount of sunlight. I have been monitoring the system with Sunny Boy Explorer and noticed if the combined string voltages exceed 500v then the output drops to 0A and 0W. This remains the case until the voltage drops below 500v.
When running normally the volatges for each string are 280-290V and 170-180V. This can then jump to over 300V and 200V and knock the system out. I believe the inverter operates up to 550V. Would changing the inverter to the 4000TL with Reactive Power Control which has a 750V limit cure the problem or is there a more fundamental issue here.
I have also noticed recently that output power has sometimes been exceeding 4.2KWh which seems strange for a system with a stated output of 3.675KWh.
The installers have been around a couple of times and seem a little mystified but have suggested replacing the inverter as a first solution.
If anyone can offer me some advice I would be most grateful.
Cheers
Motters
Cheers
Motters
