Solar Panel Pole Mount? | on ElectriciansForums
Discuss Solar Panel Pole Mount? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I
ibby
Hi
Got a question guys, does anyone have any information who would supply, a pole with with a bracket to take a solar panels?
thanks
You can have up to 9m2 of PV area for a ground mount (about 5-6 panels) before planning is required.
There are other conditions such as adhering to a minimum distance away from neighbours fence etc. that should be checked out before proceeding.
Reply to Solar Panel Pole Mount? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
I wish I needed a solution to me keep needing get batteries out my 6m boat!
