Discuss Solar PV on Duoplain/ Double plain style tiles in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of
tiles. These are sort found on new build houses. They are interlocked and nailed. Has anyone go experience of fitting solar to roofs with these? what mounting system did you use. Any tips to avoid cracking the
tiles.
thanks
Reply to Solar PV on Duoplain/ Double plain style tiles in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Crikey that sounds really complicated…. Never fitted Solar but would be interested how you get on … with pics if you can & good luck😎
Hi everyone, I work for a team called Greenworkx, where we help people get into green careers by offering training and job opportunities.
One of...
Hello Ric2013, MJPD29 and westward 10.
I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
Help please, this is my first post on this subject regarding solar panel / battery installation into house with 3 phase supply.
I am a DIY level...
If they work through the great British weather…. I’m sure a little bit of glass isn’t going to hinder them much.
