Hi All,
I've been curious for a while as to how my Solar PV is doing compared to a 'typical' install.
Recently, I purchased a Smappee (which is darn useful), and I have also now joined pvoutput.org which is now building a clear picture around my generation and usage.
However, I wanted a simpler way of calculating how well (or bad) my Solar PV array has been doing since install, which was way back in 2011.
So, being a fan of MS Excel, I have created the attached spreadsheet to do the job for me.
Please note that I had to upload it in ZIP format, so you'll need to unpack it before using it.
It is a simple tool to use, all you need to know are the following details:
1. Your Solar PV array size (in KW)
2. Your orientation (Only does South or East/West at the moment)
3. Your installation date
4. Your latest PV generation meter reading.
Enter these into the spreadsheet and it will show you the following:
1. Your FIT Rate (in pence)
2. Your export rate (in pence)
3. The Current FIT rate
4. The current Export rate
5. Your average generation in Kwh per day
6. Your average £ earned per day (including export)
7. Your average £ earned per year (including export)
And also it will show you the comparison of your PV array compared to 'standard' UK solar generation figures. (I know these are going to be approximate, but you'll at least get a rough idea).
There's also a Chart at the bottom, showing you where you sit amongst the different types of PV arrays.
If you want to check where I'm getting the comparison data from, the second tab called "Data" has the data and the links included).
Feedback would be great on whether this is actually useful to anyone out there, but it's satisfied my own curiosity on how well my system is apparently performing.
Cheers,
Leighton
Cheers,
Leighton
