Solar pv power generation? | on ElectriciansForums
Discuss Solar pv power generation? in the DIY Electrical Advice area at ElectriciansForums.net
dgstrange
Devon UK
I have a 5.9kW solar pv array and an 18kWh FoxESS battery with a H1-5.0-E inverter which has been operating for a few months
very satisfactorily. My problem exists with the data that the app gives me. The battery is topped up each night with Octopus Go cheap rate electricity, which runs the house for most of the following day. At this time of the year there is precious little solar, but the app records the total power output of the array as 12.5 kWh today, which obviously includes output from the battery. How do I find out what the total power output of the array is without including the nightly charge of the battery? Thanks.
Reply to Solar pv power generation? in the DIY Electrical Advice area at ElectriciansForums.net
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
