One of my domestic electrical customers has recently had a 4Kw solar PV system installed.
The area in the garage next to where the array was located does not have easy access to the main Consumer Unit so the installers have installed a 2-way garage consumer unit to connect the inverter. This 2 way garage unit obtains its supply by breaking into the original local 32 amp ring circuit to use as the main supply conductors. This original ring circuit is protected by an rcd at the main consumer unit and since the PV system has been installed the rcd at the main consumer unit trips on a very regular basis.
I have tested the rcd on the main consumer unit and it operates as it should.
I would like to know if this type of connection is acceptable as I believe that the inverter should be on its own dedicated circuit that is preferably non rcd protected.
Can anyone give me advise please.
