View the thread, titled "Solar PV trippiing RCD" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
C
cadspark
I had a call from a chap today who owns a holiday cottage with a PV array which he says trips the RCD on his sockets occasionally. The house was rewired 7 years ago and he says it's only since he had the PV put in that it now trips the RCD. I won't be able to look at the job until he is down at the weekend so I'm just looking for a heads up if anyone has any experience of this happening and what I should be looking out for.
One to check, check that the RCD is designed to cope with pulsating DC currents, some PV inverters can put out a strange waveform. The RCD may have also come senstive over time so do a ramp test and do an earth leakage current test in situ.
It will be a transformerless inverter, and yes they do trip RCDs, due to leakake currents up to 100mA.
Reply to the thread, titled "Solar PV trippiing RCD" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
