Shento
Can anyone help, looking to put a 3kw system onto a container to enable me to charge electric golf karts 36/48v other than the modules would I need an inverter?
Discuss solar system to container in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
thanks for the reply,not unless you require AC.
ThanksUsing a charge controller, you would need to find panels with a close match to the required charging voltage and a good reliable charge controller or series of charge controllers. You then wire them in parallel to give lots of amps.
If you do not want any feed in tariff that is the way to go.
Alternativiely you could convert to AC using an inverter, and then convert back to dc via the normal chargers. It will need to be grid connected, or use a device like sunny island to simulate the grid so that the inverter has something to match voltage, frequency and phase to, of course that way any excess not being used by the chargers would be available for the club house, you'll also get a Feed-In Tariff payment for what you generate.
The last one also has the advantage that the buggies will still get charged from the grid, even when the sun isn't shinning!, If you want make sure that you're running on generated power as a priority a cheap controller like this, Solar Immersion Heater Switch - Use Surplus Solar PV Power to Heat Water & Save Money or this .:Energyfactor UK:. - Energy consultancy will only divert power to the chargers when the sun is actually shining.
Reply to solar system to container in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
