Solar tripping double pole rcbo - Generation Meter Issue? | on ElectriciansForums
Discuss Solar tripping double pole rcbo - Generation Meter Issue? in the UK Electrical Forum area at ElectriciansForums.net
rolyberkin
Nearly Esteemed
Chelmsford
Any suggestions, all cables are fine, was moved from a single pole rcbo to a double pole yesterday and I think appears to be something to do with the generation meter as this is the only issue in between. Does the system have to be on a single pole rcbo?
hi rolyberkin
does the system require an RCD in the first place some systems require a special rcd I think A type if I remember correctly. use manufacturers guide from the inverter or inverters depending on set up.
Reply to Solar tripping double pole rcbo - Generation Meter Issue? in the UK Electrical Forum area at ElectriciansForums.net
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
