Hi!
I want to solder a TRS cable to a circuit amplifyer.
The amplifyer has +, - and OUT as outputs. I have heard that it should be possible to use a 3.5 mm TRS cable but I'm wondering to what output I should solder the wires from the TRS cable.
Someone told me that I should use either TIP or RING to out and then SLEEVE to -. Is that correct?
I have attach an image of the amplifyer and the TRS cable.
Thank you!
Thank you!
