C
Callum Jackson
My assessor is insistent I get soldering evidence for my folder, I have no idea what I'll solder I have
Never soldered at work... I've got a solder gun I basically need to make it up and mock up a couple photos.
Can any suggest anything I can solder? I was thinking a LED for a emergency lightreatment and maybe a battery pack?
Any help would be very appreciated I'm at a bit of a loss.
Thanks guys
you could solder some T/E for a joint. have the heat shrink ready to slide over.
Upvote 0
Have you been taught the basics of soldering on your course or are they expecting you to be coached at work?
Upvote 0
Every now and again, I use heatshrink solder connectors (a bit like the heatshrink crimp ones, but a ring of solder instead of a crimp tube). I normally use a hot air heat gun to melt the solder. Today, I used half a dozen to repair some stranded 12V lighting cables (cable too thin for crimps). Good to have these with me as an alternative.
My conventional soldering iron, I mostly use for repairing printed circuit boards nowadays - changing failed components.
Upvote 0
I never thought of doing a joint that's a good idea i can do one T/E joint and maybe a joint for a set of dimming pairs or maybe ill grab an old EM fitting and just say i'm replacing a battery pack.
and no i've never be taught how to solder at college they seem to expect it to be on the job but i asked my boss the last time he picked up a solder iron and i think he said about 8 years ago to fix a control circuit on a motor or some gaff but that's was years ago seems like a strange requirement.
95% through my folder now i'm getting very used to the answer "Because that's what the IV wants" i've stopped questioning.
Upvote 0
I would in your case then do some research or you will more than likley end up with poor/dry joints etc, which you won't be able to identify by simply looking... just read up on the basics and the do's and dont's with regard to soldering and you should be fine.
Upvote 0
Thanks for the advise guys I'll have a little think and a talk to my boss see what I can come up with. And yeah think your right probably something that I should learn properly if I have to do it anyway! I'm sure at some point I'll need to do it for real.
Upvote 0
if you cant get 63/37 60/40 is more readily available.
have a look on yourtube im sure element14 did some video guides on soldering and tinning.
tinning is always a good idea to help it stick and put a little solder on the iron then on a damp sponge to clean it.
(i think eevblog has a video guide as well)
www.makezine.com/2007/01/05/soldering-tutorial-make-v/
Upvote 0
And if you have never burnt yourself with the solder iron by accident then you haven't crossed the crucial step to becoming a competent solderer :smartass2:
Upvote 0
buy a decent one and no issue with the vent [emoji14] never been burnt by my weller pyropen
For the frequency of use (rare) its not worth going all out on a good quality and design - mine keeps me on my toes too as I'm always aware of where it is and what it is facing - little room for complacency when you have already had your finger burnt (literally) :)
Upvote 0
Any questions on soldering let me know, for I have been soldering since I was 5 years old and working in electronics for 16 years, I am about to do the ipc 610 test so that I have a bit of paper saying I can actually solder, a bit pricey buf absolutely everything nowadays gets asked for a ticket to prove it...even if you are good at it and been doing it for nearly 30 years...."here's my previous work"....."NO! have you got ipc 610?!?" (rolls eyes)
Upvote 0
Thanks guys
Scrounge a bit of, say 25mm single and solder a lug on the end.
Upvote 0
Soldering????
Electrician Courses : Electrical Quals
Thread Tags
Tags Tags
None
Callum Jackson,
7029 dave,
Electrical Courses
