Soldering | on ElectriciansForums
Discuss Soldering in the Australia area at ElectriciansForums.net
T
timo
Anyone using soldering when joing conductors? Regs says its a method that can be used that doesnt need to be accessable for inspection. So just wondering if anyone solders their joints and heat shrinks etc?
Is there a certain flux/solder for the job?
Where does it say that? I was under the impression we werent allowed to solder. Would love to be proved wrong, and especially if we don't have to have accessible jointing.
I do a lot of miniature soldering i.e. elecronics. I always use old leaded solder (got a stockpile of it - thanks dad!) and just plain old plumbers flux. There's probably a reason I shouldn't, but I find all electrical grade flux a pile of poo. If you do use plumbing flux though, make sure you clean the area down well after as it's water based.
Wago connectors every time available at gil-lec.co.uk
I'm getting in to the old Wago connectors also.
Wouldn't think to take me old antex along to a job, and the last time I wanted it I couldn't find it.
Put it down to another item that went missing (sorry I misplaced) around the time my X wife's father help her move out ;).
Jim
Rocker - grab your regs book mate. Look at page 106
Section 526 (Electrical Connections)
526.3
part iv
Not too keen on crimps. A few times after making off i notice they can come lose if the crimp doesnt grab 100%
I think they should be crimps around an cm longer so you get a good 10-12mm in each side.
i have used soldered connections a few times mainly on heavy duty flex connections biggest being 95mm.
For smaller stuff i would use a crimp everytime however its a techneque that comes in handy now and again.
526.3
part iv
Tidyyyyyyyyyyyy
Couldn't agree more. Only today I was thinking 'why don't they give these things another half inch of grip?' Think I'll solder in future though if it's being permanently covered.
Reply to Soldering in the Australia area at ElectriciansForums.net
This is an RSS feed of thread: Hole in copper pipe, solder under floor, T coupling & protection Content of the thread: I was stupid enough not to...
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
