Solid plaster partition walls with straw inside:fixing boxes? | on ElectriciansForums
Discuss Solid plaster partition walls with straw inside:fixing boxes? in the UK Electrical Forum area at ElectriciansForums.net
shipley
Came across these yesterday and wondered if anyone on here has seen them.Solid plaster with horizontal strands of straw inside.I finished up cutting the holes with a multisaw then driving 75mm screws thro the sides of the twin metal boxes,since plastic plugs were useless.Never seen these walls before and wondered how they were constructed on site.Thanks for any replies.
Regards,S
The ones I've come across, the have vertical channels at regular intervals for cabling, you just have to locate where they are, and can then site any new accessory boxes to align with the channels. I've usually just used long screws from the sides of the boxes, as you mentioned.
Reply to Solid plaster partition walls with straw inside:fixing boxes? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
