G
gerard
Hi,
I am using the relays of a control panel to switch on a single phase contactor. This contactor then turns on a motor. The relays are 24V dc rated and inside this control panel there is electronic circuitry. I am worried that the back emf created by the contactor coil might damage the relays or even worse, damage the electronics inside the control panel. Would it be better to use a solid state single phase contactor rather than the conventional contactor to prevent this?
