Solvent or push-fit? plumbing advice | on ElectriciansForums
Discuss Solvent or push-fit? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Solvent or push-fit? Can anyone explain why we have two different sizes of waste pipe for solvent weld and push-fit connectors? Why didn’t they just make the push fit connectors a bit bigger so they would push on a solvent weld pipe rather than have the confusion of needing a different size pipe and compression fittings to switch between them? It would make sense for the manufacturers and stockists too in almost halving the inventory they have to carry.
Solvent or push-fit? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Solvent or push-fit? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
I
weeping solvent weld joint Hi, I have a weeping solvent weld joint on my bathroom sink. What's the best way to seal it please? weeping solvent...
Iankkk
I
Help joining waste pipe to shower waste please Hi, just a quick question about the standard way you connect 40mm waste pipe to the outlet of this...
dameo220
