C
carlos54321
hi all,
i have a small steam press (sorry wife has a steam press inside the lid of the plate it has a thermal fuse which i have replaced and is fine, but it also has a diode this is for the steam,so i think when it come's to temp it activates the diode which then i turn allows you to have steam (or should i say water is allowed to go to the plate that is hot to create steam)
this diode has no markings its clear glass with like a bit of solder in the middle what im needing to know is this a silicon diode or aZener diode.
if you need photos or info to help me no worry's im just hoping someone might know off the top there heads.
thankyou
thankyou
