A large school im working on has upgraded their supply from 200a TNS to 315a bs 88 - 185mm tails TNCS/pme, current bonding is only 16mm looped off local SWA armouring points around the school that are supplied from main intake
around 300m of 50mm earth to install, 4 main gas intake meter points, 3 main water intake points, school is split into 3 main buildings, 4 new MET positions and a shed load of p clips :0
cheapest i can get 50mm is ÂŁ3.35 per meter from eddys, most expensive was cef(no surprise)
