A
andart
I have read all the threads on changing a CU but have a couple of extra questions I hope you can help me with:
1. The cable ends I have are just long enough for the new CU but not quite long enuogh to let me get all the earth connections in the correct order (to be honest it looks like a cats cradle) - what can I do about this?
2. the old set-up had 6 circuits on an old fuse wire box with a pair of leads feeding a box with 2 x 40amp mcbs for the electric showers - I have incorporated these in the new box (100 amp main switch, 15 way, split load, dual rcd protected 1 shower on each rcd) but when I work out total load I think its going to exceed the 63 amp max allowed for a 100 amp switch - is there any way round this?
3. the service fuse is 60amp - we have lived in the house for 3 months now without any problems but should I be thinking about getting the DNO to increase the fuse (they have told me 80 amp is the max I could get, subject to survey and a load of dosh!)
any help greatly appreciated!
andy
andy
