some sockets not working | on ElectriciansForums
Discuss some sockets not working in the DIY Electrical Advice area at ElectriciansForums.net
M
Mark Paton
HI this is my first post
the sockets on 1 wall in living room not working , 1 socket in kicken on same wall not working,
hall way socket not working, all sockets in front room not working . no electric to the heating
this is an old farm house , no fuses blown , can any 1 help cheers
i am not a spark.
it has an old fuse box,
the 1 you put fuse wire in
Is your meter local to your fuseboards.... do you have a tripping device that protects multiple circuits that may have tripped ...without knowing the layout of your install its very hard to advice someone with no electrical knowledge other than get a competent Electrician in, it could be a simple solution that will also give you an heads-up in future but it could also be a fire hazard if you have a burning out cable.
Its not something we can really help on anymore than check all trips and fuses are good if they are then you need an Electrician!
i am not a spark.
You are not going to fix this through a forum. It could be something as simple as a loose connection, it could be as serious as a damaged cable. The correct testing sequence will show the fault and its rough location in a short while, but you need the correct kit and knowledge which only an experienced electrician will have. So bite the bullet, and get hold of one, give him or her all the information that you have about the problem, and if you have done anything that you have not mentioned, then tell them. it was always the first thing i asked a customer "Have you done anything you need to tell me about, cos if you have tell me know, because i will find out, and if you tell me now it may save you a heap of cash"
Good luck,
Howard
Reply to some sockets not working in the DIY Electrical Advice area at ElectriciansForums.net
i am looking at outdoor security lights, hard wired with PIR sensors but there are so many options .. any suggestion on brand or what to get would...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
