Some strange substance coming out of space heater | on ElectriciansForums
Discuss Some strange substance coming out of space heater in the UK Electrical Forum area at ElectriciansForums.net
adfrank
Brooklyn, NY
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my issue, and this forum is what I came up with.
I have a small bathroom Lasko space heater (1500w). I bought it around 3 years ago and my wife and I use it only during winter when using the bathroom/shower. This winter I noticed some strange light-colored substance seemingly coming out of the front of the space heater. The substance is hard to the touch. It seems like maybe something melted, oozed out of the heater, and then hardened? I'm not sure.
The below photo is a close-up of the grill through which the heat comes out.
Does anyone know what this could be, and whether it's something I should be concerned about?
[ElectriciansForums.net] Some strange substance coming out of space heater
If as you say it’s a heater. Not often used in a moist bathroom environment, and behind a grill in a darkened area….
It could possibly be a Fungal Spor.!!
Remove the grill and heater unit and clean out thoroughly in a well ventilated area.
On the other hand .????
If you have young children, it could well be a Crayon or such like that the little darlings have shoved through other grill.
Good luck, let us know.
Is this a free standing heater that you use in the bathroom?
It's apparently designed for use in a bathroom (but a bathroom in the USA!)
Yeah, left untreated you end up with a case of this...
Reply to Some strange substance coming out of space heater in the UK Electrical Forum area at ElectriciansForums.net
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
