matt1386
Hi all, im struggling to get my head around how to find the value of unknown resistors in parallel, here is the question I have to answer :
Two resistors of 48 OHMS and 80 OHMS are connected together in parallel. What would the value of a third resistor have to be, when connected in parallel with the first two, in order to give a combined resistance total of 15 OHMS ?
Please could somebody explain how I work this out in simple terms lol
Im not asking for answers, just for guidance to make me understand
Thanks very much
Matt
Knowing the formula for resistors in parallel, insert the values given, then rearrange the equation to make R3 the result.
Ok first find the combined value of the 2 known resistors in parallel using the formula
1/Rt = 1/R1 + 1/R2
Once you have this value which we will call R? for now use this and your total resistance that you have for all 3 in this formula
R3 = R? X Rt / R? - Rt
Have a go and post your workings then I will give you your marks out of ten :)
Thank you guys for your quick replies, its much appreciated
Ok Sintra, ive had a go, here is what I got ( probably look an idiot now if this is miles out lol )
1/48 + 1/80 = 1/0.03 = 30 ohms (Rt)
30 x 15 = 450 / 30 - 15 = 15
450 / 15 = 30 ohms ( R3 value )
Am I anywhere near ?
Thanks again
Matt
Oh brilliant, thanks for that Sintra
Im still not 100% on understanding how its all worked out but now I know the formula I can practice until it sticks :-)
Thanks again, appreciate the help and advice
No probs knowing the correct formulae is always good starting point :)
matt1386
Bradford
Somebody please help me out here...
Electrical Course Trainees Only
Thread Tags
matt1386,
Sintra,
