R
rusty
Sorry - I'm not trade, I don't have anything long term to contribute to this forum and professionals like you guys probably have limited time for people like me who try to go it alone and then mess up - but I'm hoping one of you will indulge me with a one off question.
My father and I recently did my home bathroom. On the basis that the existing wiring on the old light supply was recent large cable and solid, we branched the existing light supply into two with a junction box. One branch runs a normal B&Q halogen light fitting, the other one runs an identical light fitting and in series a standard bathroom extractor fan. The wiring was all then sealed in with an insulated tongue and groove false ceiling that as you might understand I'm not keen to take apart and re-jig if I can help it. All was done with proper mains cable, and the light fittings use 60 watt capsule type halogen bulbs.
On the branch that (as I remember it) also runs the extractor fan, the bulb blows every couple of weeks. This always trips the RCD. Does the effect of having an electric motor (and the current fluctuations that probably causes) running on the same wire cause halogen bulbs to blow? Is it likely that the way it is done is fundamentally dangerous/wrong and do I need to take the roof apart and add a third branch for the fan, or do I need to just replace the existing light fittings with one that uses a different type of bulb that is less susceptible to having a motor running on the same wire?
Again, sorry for posting a question like this in a professional forum, hopefully one of you kind souls will take the time to humor a beginner, even if just to ------- me for not using a professional in the first place. Thanks in anticipation!
