sorry if in the wrong place.. but im new | on ElectriciansForums
Discuss sorry if in the wrong place.. but im new in the UK Electrical Forum area at ElectriciansForums.net
Runcorn, England
hi everyone.. just a quick heads up.. i'm currently fixing a tv set and i've found the piece that i need to replace, but it's nothing that i know about. any help would be massively appreciated :)
[ElectriciansForums.net] sorry if in the wrong place.. but im new
Which part? Red/brown parts are capacitors, and the white part (I think I can just make out the writing) is a 10 ohm 5W resistor, which would be expected to run warm and discolour the board over time.
looks bigger than 5w to me.
Often when a resistor is burnt / open-circuit it is only a symptom of the problem, not the problem itself. In PSUs especially, many failures take out half a dozen parts at the same time, some of which will show no outward signs of damage. But if you don't change them all in one hit, and then start the thing up on a lamp limiter, the one bad part you left behind will destroy all the others again.
Repairing electronics only by what looks burnt, is going to need a lot of luck on your side! Post the model number, link to circuit diagram if you have one, symptoms, readings you have taken etc. This is not a TV repair forum but some of us know a thing or two about electronics.
Reply to sorry if in the wrong place.. but im new in the UK Electrical Forum area at ElectriciansForums.net
Just to say that the description of that safety bulb-holder does confirm if you take the bulb out, the pins are not live, even if the switch is...
By the looks of it the whole head comes off in one unit, guess it has a driver inside of it. Ive tried to Google the Image i have, one comes up...
