Spa installation instructions | on ElectriciansForums
Discuss Spa installation instructions in the Electrical Tools and Products area at ElectriciansForums.net
P
pabloiseguro
Hello. Regarding some Spa installation instructions, I can't understand the underlined sentence:
The SPA tub should be connected to the building’s electrical wiring permanently. The electrical wiring should be equipped with theappropriate manual cut-off mechanism, enabling the opening of contacts on each power supply pole.
Any ideas?
Any ideas?
To any Electrician, it's stating the obvious, therefore hire a qualified electrician to install the Spa's electrical installation!! Don't be tempted to undertake this work yourself, there are other safety factors that need to be taken into consideration apart from this manufacturers instruction.....
I don't suppose the OP is one of those guys rolling up on hot tub jobs and just whacking them into IP rated socket outlets?
Far too many crappy hot tub jobs out there. Come to think of it, I don't think I have ever seen one done correctly?! (apart from mine that is :D).
Reply to Spa installation instructions in the Electrical Tools and Products area at ElectriciansForums.net
I'm going to get the wording wrong because I am far too lazy to look it up. A previous version said 'must be followed' now says 'should be taken...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
