space factor | on ElectriciansForums
Discuss space factor in the UK Electrical Forum area at ElectriciansForums.net
davidewdave1
I want to spur one double socket off of an existing socket using 2.5 t&e run in pvc mini truncking,what size truncking should I use?
to calculate the size I think he should divide the length by the number of sockets and multiply by a factor of 1.2 then add 2.5mm and then spray it pink with a green lid.
Reply to space factor in the UK Electrical Forum area at ElectriciansForums.net
Why aren't you asking them?
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
