Spanners for swa glands | on ElectriciansForums
Discuss Spanners for swa glands in the Electrical Tools and Products area at ElectriciansForums.net
Northwest
Hi good evening chaps
just a quick question for the life of me I can't remember what size spanners are suitable for 20s,20 and 25 mm glands dont really want to use adjustable they can be a bit tricky getting into awkward spots.
Any help would be gratefully appreciated
Hi thanks for the quick replies due to it being in a hazardous area there's no shrouds and any form of marking on the glands is a no no lol. I never thought of that it's a good idea lol cheers guys
how about a pair of these
Ridgid E-110 Hex Wrench
[ElectriciansForums.net] Spanners for swa glands
sold at toolstop
Cheers for the replays chaps I'll be looking into your ideas I have a set of them rigid E-110 there really good I find them a ball ache at times when your glanding in a confined space there really good for bigger glands
There's no simple answer to the original question as differing brands engineer the glands to their own spec's giving variable outer diameters for the same 20mm/25mm glands.
As above adjustable pliers the best - if your having issues with confined spaces a lot then re-design the install to ensure glanding is easier for install and maintenance.
cant you cover the gland in some kind of amalgamating tape if shrouds are a no go, afterall the cable is covered in pvc so they shouldn't moan at pvc tape.
if damaging them wasnt a problem I would be tempted to use stilsons
Never heard of that one before, so what's the reasoning behind that little gem then?? Shrouds can be slipped down for gland inspection and any glands used, will be of the suitable EX'd type!! So i'm at a complete loss, considering the shrouds protect the SWA against the elements etc????? lol!!
We use adhesive lined heatshrink on all our external SWA glands, and personally i'd be using the same on hazardous area installations as well, unless anyone can give me a good reason not too?? ...lol!!
Reply to Spanners for swa glands in the Electrical Tools and Products area at ElectriciansForums.net
