devlin maguire
Took the cover off a CU and as I always do Ze 1st Iwas checking to identify the main earth conductor as sometimes the main bond will be run in 16mm, but at first look it seemed that there was no main bond I took out the main earth and tested for Ze then i saw a10mm earth peeking out from behind all his little cpc freinds but there was no bared end, so I dug it out and tested it back to the airing cupboard where the water boiler and pipes are and it read 0.17 I put the croc clip on the earth bar to see if there was any thing there and I got 0.01 connected the "spare" earth to the MEt and it went up 0.15, so I have acceptable reading with this conductor off so any ideas why its there and where it goes .anyone??
Mac
Mac
