sparking | on ElectriciansForums
Discuss sparking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
a switch fused spur, sparks when the switch is flicked off only. when it is switched on it dosent any ideas wot it could be? lose cable?
Reply to sparking in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Requirement or not, I've not installed a domestic lighting circuit without RCD protection for double that.
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
