spd in meter box? | on ElectriciansForums
Discuss spd in meter box? in the UK Electrical Forum area at ElectriciansForums.net
pembs
Client needs an SPD fitting but no room in c/u or adjacent. Best bet looks like a parallel connection into the tail blocks in the meter cabinet with an adjacent 'standalone unit' ie with overcurrent protection. Anybody done this? Any reason I shouldn't? Is it ok to use board PEN connection block for earth?
Wylex do a tail isolator with type 2 SPD that's rated at 100A so no need to fuse down. This is what I would use just make sure you get your supply and load around the right way round.
[ElectriciansForums.net] spd in meter box?
Same idea but 1/4 the price...! Have fitted both and not a huge difference in quality tbh , Wylex obvs the benchmark though but I'll be mostly fitting the WCED ..
Reply to spd in meter box? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
