Special locations | on ElectriciansForums
Discuss Special locations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
nrbspark
I have to install over basin water heaters in 2 bathrooms as there is no domestic hot water, there is rcd protection in the bathrooms so is it ok to fit an un-switched fused spur in zone 2 as long as the manufacturer permits the plate to be used in this area? Any help would be appreciated thanks.
If its over sink heaters because there in no hot water available what else is in there? if it is just a toilet and wash hand basin its not a special location
Reply to Special locations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
Bathroom leak disaster- wet room the culprit? Hi there, Several days ago the plaster board of my living room ceiling collapsed, as a result of a...
Lisa2021
L
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
