L
Discuss Speed Control of Motor using SCR in the Electrician Talk | All Countries area at ElectriciansForums.net
Thank you so much uncle Betty.
I think the motor will never turn ON if the capacitor C1 is shorted as the diac will remain off. Could you please confirm this uncle betty? Thanks!
Or the motor will always be running as the voltage across the resistor keeps the Diac ON. I am confused
Hi, any inputs on how does this circuit(this actually uses SCR) is used for speed control of motor?
Thanks much.
Reply to Speed Control of Motor using SCR in the Electrician Talk | All Countries area at ElectriciansForums.net
