spike=ze? | on ElectriciansForums
Discuss spike=ze? in the Australia area at ElectriciansForums.net
northern ireland
hi folks would i be right or wrong sayin that the spike readin in a tt system is therefore also the external loop impedance? replies much appreciated:D
Reply to spike=ze? in the Australia area at ElectriciansForums.net
To give you some idea....with my DNO, the question "Can you see arcing, sparking or smoking?" is 3.5 minutes into the automated call answering...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
