split 10mm to cooker and hob | on ElectriciansForums
Discuss split 10mm to cooker and hob in the Electrical Course Trainees Only area at ElectriciansForums.net
sussex
previously to now i have only ever wired ovens with the hobs built in a friend has asked me to fit cables to supply his new oven and hob which are on different walls however he wants it done on cheap using existing 10 mm supply providing it tests out fine he hasn't ordered the new units yet which doesn't help but it will be a dual over so guessing i cant take off the 2.5 ring can i use a dual outlet? plate does it need fusing down? I have also advised his that its notifiable however i'm looking at joining a scam very shortly.
ideally i would run 2 separate supplies but due to decor etc he's saying no
why do people never consider the electrics before doing everything else
Reply to split 10mm to cooker and hob in the Electrical Course Trainees Only area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
