split board test rcd b rcd a trips | on ElectriciansForums
Discuss split board test rcd b rcd a trips in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
silver
installed a spilt board today 5 on one side 5 on other,made sure the cct did not get mixed ,start testing rdc b side first mainly because they are all radials cct, did loop on no trip rcd a tripped out but got the readings on rcd b why
with the cct on b side they were original heating cct on their own board and changed to single sockets which is know in a spilt board all socket were tested on their own ie line 1 and earth getting R1R2 readings ok
Reply to split board test rcd b rcd a trips in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
Ok I’ll try this when I’m down
