split charge relay to charge two 6v 4.5ah batteries | on ElectriciansForums
Discuss split charge relay to charge two 6v 4.5ah batteries in the Auto Electrician Forum area at ElectriciansForums.net
waigy
fife
I have two maplin 6v 4.5ah batteries wired in series to power my dashcam while parked.
The batteries are similar to this one :
[ElectriciansForums.net] split charge relay to charge two 6v 4.5ah batteries
Will this split charge relay be ok to re-charge the batteries while driving?
Maypole 292 20A Caravan Dual Charge Relay Kit: Amazon.co.uk: Car & Motorbike - https://www.amazon.co.uk/Maypole-292-Caravan-Charge-Relay/dp/B008LUK3A8
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
The 6v batteries will be right next to the car battery and wired similar to this:
The relay I have ordered is a Tec2 20a so it uses a 15a fuse and it has an extra "ign" connection to connect to a supply that is live when the car is switched on.
My main concern is how small the 6v batteries are in ah and physically.
These split charge relays are more commonly used to charge large leisure batteries.
Reply to split charge relay to charge two 6v 4.5ah batteries in the Auto Electrician Forum area at ElectriciansForums.net
