split concentric cable | on ElectriciansForums
Discuss split concentric cable in the Australia area at ElectriciansForums.net
J
Jimmyb
Hello, What size does the old red and black 16mm split concentric cable have ?
Jimmy
Reply to split concentric cable in the Australia area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
The only things likely to be damaged by a sudden loss of power are machines that rely on a cooling pump running on after the heat source has shut...
