split concentric installation | on ElectriciansForums
Discuss split concentric installation in the Australia area at ElectriciansForums.net
M
m4fiaafg
my question is straight forward, can split concentric cable be installed underground, ie say outside buried to a large shed because i was ubder the impression that it was like armoured cable,
thanks
Reply to split concentric installation in the Australia area at ElectriciansForums.net
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
