split concentric | on ElectriciansForums
Discuss split concentric in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
devlin maguire
anyone know a suppier who will supply cut lenghs 10 meters is what Iam after but I cant get anyone local to supply
Mac
Does it have to be split concentric why not SWA. It isn't widely used in domestic environments and so not many wholesalers don't keep it on the shelf or get much demand for it.
It Isn't as common over near me in and around the south west of london I maybe corrected by someone. If I went and asked at my local Neweys they would tell me it's a special with a special price ;) and it would take two days to come in, I would get the same reaction from EDs. How much difference, diameter wise is it to an equivalent SWA 3 core?
Nice might give it a go one day. Does it not need RCD protection though if buried in a wall or underground or is that only for straight concentric?.
Hi It's common here in west scotland the board use it on service provisions with a Y shaped cover or boot below the service fuse Iam hoping to acquire some for a job on a farm after the supply is moved maybe those really freindy blokes from SSeb will leave me some :rolleyes:
Mac
Split concentric cable MUST be treated as if it were twin and earth, when it comes to installation methods as it has no mechanical protection.
Reply to split concentric in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
The only things likely to be damaged by a sudden loss of power are machines that rely on a cooling pump running on after the heat source has shut...
