Split lighting circuit | on ElectriciansForums
Discuss Split lighting circuit in the Australia area at ElectriciansForums.net
B
bobodhi
I'm about to do a rewire on an old lighting circuit. I'll have to remove and replace some wiring but not all, thing is, up till now all the circuits I've worked have followed a nice neat radial pattern, but this one is split into 2 or more sections, ie; the line from the cu is split at a jb to feed lights in different rooms not in sequence as per all the nice neat diagrams in the books.
I've reviewed the regs, but can see no reason why i should put the customer to unnecessary time and expense to wire it in sequence if the wiring is already sound and I can't detect any faults.
Is this ok or am I missing something?
Why the rewire in the first place does that reason apply to the rest of it that you want to leave as is if it does not apply no reason the change it if all tests check out.
Hope that helps
Chris
Hi, sorry but I don't think you understood my question. The re-wire is necessary, some of the wiring is old rubber and is disintegrating, it has been attacked by rodents and lacks cpc's. Hope that covers that.
My question is, the wiring does not follow a strict radial circuit pattern as I understand that to be, a continuous sequence from first light or jb to the last, it is instead split into several radiating sections, a bit like the spokes of a wheel radiating out from the hub, that being the first jb after leaving the cu. What i need to know is, once i've replaced the faulty sections, is this acceptable as a wiring solution, it may not be 'best practice' but as i am doing a re-wire and not an initial installation is it acceptable as far as the regulations apply?
Thanks, Kevin
A radial circuit can take many forms
It does not have to be one to the next to the next and so on
The word radial means to radiate,as in your bicycle spoke example
If you make a junction for them to do so,then it has to be accessable for inspection or it has to be made with permanent joints
If it is a standard jb
A junction box,hidden away in a cupboard or located in an accessable attic would be ok
A junction under flooring may not be considered accessable,its a matter of opinion
Surely that still is a radial circuit? What difference does it make whether it's one run or has branches off it, I've come across this many times, installed new lighting that way before and seen diagrams showing similar setups. As long as your JBs are accessible go for it
OK Folks, thanks for all those answers, i couldn't see any reason why my circuit would be invalid from an engineering point of view, just wanted to make sure I wasn't breaching any rules and or regs that i might not be aware of, after all i'm only a lowly spark, not some degree'd and fellowed electrical engineer who might know of some arcane electrical phenomenon that could bring me grief... lol, or in other words 'better safe than sorry'!
Reply to Split lighting circuit in the Australia area at ElectriciansForums.net
