Hi Guys,
During a visit to a rented property on behalf of a local agent it was noted that the RCD in the split load board was 100mA. The property is a 1st floor flat, PME and the protected circuits are cooker & sockets. It's a Proteus board with a beast of an RCD that swallows up 4 ways! Probably installed late 80's early 90s.
Assuming it would of probably of been installed during the time of the 16th Edition, would it of been to regs of the time bearing in mind that it's a first floor property (no garden or sockets feeding equipment outside) which negated the need for any RCD protection anyway, assuming (again) things like main bonding & supplementry bonding were all present and correct.
Like to know what action you might take if you came across this as I'm in two minds on how to proceed.
Cheers
Cheers
