DNS
I was discussing the wiring of split load twin RCD consumer units with a friend last night. I wire them with the largest MCB amps next to the RCD (first feed) then decreasing down to the smallest eg. 6 amps. He disagreed and said it should be the other way, smallest first. I tried to explain that the largest demand should be first..... etc... He threw his teddy out of the window then. I have tried to find this in the books/guides, but I can't find it. Please can you settle this argument, I am right aren't I. Thanks....
