Split Phase metering (one meter or two) | on ElectriciansForums
Discuss Split Phase metering (one meter or two) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
GreggElectrical
Installing 10kw on a split phase / 2 phase / 480v / single phase, 3 wire (or whatever you want to call it) supply.
system is made up of 2 x 5kw arrays with two single phase inverters. Do you meter each inverter separate or can you use one three phase meter and just not use one of the poles?
Hi there Greg.
I know it's a long time ago. How did you get on with this one?
i have to wire this soon.
From what i am aware i think you can do it with L1 miss out L2 and use L3 ....
Did it work in your case??
regards
Reply to Split Phase metering (one meter or two) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
