DmsF
Hi,
I have 2.5mm tw+e on a ring which has now been heavily insulated. (After the wiring work unfortunately) It is not really an option to rewire in 4mm back to the CU, or sufficiantly extract enough of the wires above the insulation. It serves two bedrooms (5 doubles apiece), currently with a 32A RCCBO at the CU.
Looking for comment on the acceptability of dividing it into two separate rings in 2.5mm with either 20A or 16A RCCBO serving each room independently.
Taking it a stage further - is it beneficial to plan for putting each other non-kitchen room on own ring with 20A RCCBO? Or would this look excessive?
(the property is not 4mm friendly - so I would prefer to get a safe, quality 2.5mm solution, and undertsand that I need to recognise that substantial insulation will be needed to keep runing cost to acceptable levels)
Cheers,
DF
Cheers,
DF
