Spot light types | on ElectriciansForums
Discuss Spot light types in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Spoon242
Guys,
I am calling in at a customers home on my way home this evening to look at a spot light which has stopped working. I don't know if it's a simple as the the lamp has blown or indeed what type spot lamps are fitted.
The cutomer also complains of brown staining around the fittings which they also would like looked in to.
I was reading the other day somewhere and can not remember where about GU10's and the different types available, does anyone have a handy guide I can print out with the GU10 type symbols on please?
Reply to Spot light types in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Ironically when order from HSP arrived it was a weird ZAG 1 igniter. It has a sticker on it with the PCB part number but says Ignition generator...
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
